Community Member
RV180 IPSEC Problem
I get the following error when I try to intiate an IPSEC connection from my Android phone. It have similar error when connecting thru Cisco VPN client on my PC. Anyone knows how to fix this problem. I have a RV180 VPN router.
Sun Jul 08 18:43:09 2012 (GMT -0700): [rv180] [IKE] ERROR:  Local configuration for xxx.xxx.225.137[49534] does not have mode config
Andrew
RV180 IPSEC Problem
Hi Andrew,
Please post your config and I will look into it for you.
thanks
Community Member
RV180 IPSEC Problem
Thanks for your help. Following is the VPN Configuration:
Selected IKE Policy View
General
Policy Name:49Home
Direction / TypeResponder
Exchange Mode:Aggresive
Enable XAUTH Client:
Local Identification
Identifier Type:FQDN
FQDN:local.com
Peer IKE Identification
FQDN:remote.com
IKE SA Parameters
Encryption Algorithm:AES-128
Authentication Algorithm:SHA-1
Authentication Method:Pre-Shared Key
Pre-Shared Key:26448f97d55d
Diffie-Hellman (DH) Group:Group 2 (1024bit )
SA-Lifetime:28800 Seconds
Add / Edit VPN Policy ConfigurationPolicy Name:
Policy Type:
NETBIOS:
Enable
Local Traffic SelectionLocal IP:
Start Address:
End Address:
Subnet Mask:
Remote Traffic Selection
Start Address:
End Address:
Subnet Mask:
Split DNSSplit DNS:
Enable
Domain Name Server 1:
Domain Name Server 2:
(Optional)
Domain Name 1:
Domain Name 2:
(Optional)
Manual Policy ParametersSPI-Incoming:
SPI-Outgoing:
Key-In:
Key-Out:
Integrity Algorithm:
Key-In:
Key-Out:
Auto Policy ParametersSA-Lifetime:
Enable
Select IKE Policy:
1111
