RV180 slow in router mode
Hi there
I've just bought a RV180 router.
The firmware is new:
Release 1.0.3.10
If I use the device in Gateway Mode I got speeds in test and downloads about 500Mbit/s, that would be good (tested directly at a 1Gig Backbone).
But I wanna use the device in Router Mode so that I can use different public IP's in the LAN. That works but the speed falls dramatically to onyl 70Mbit/s.
Why is that speed so slow? that's useless for me.
I have disabled all QoS/Security things which could affect the speed
Gold
Michael,
I'm not sure what is causing the slow speed in Router Mode, you may want to open a case for that:
www.cisco.com/go/sbsc
Can you use One-to-One NAT to translate the public IPs to private IPs on the LAN? That might be a good workaround to get the speed that you desire.
Please reply if you have any questions.
- Marty
Bronze
Sounds like you've discovered a bug.  I'd use NAT one-to-one as a workaround, assuming it works at full speed.
Huntsville's Premiere Car and Bike e-magazine: www.huntsvillecarscene.com
1:1 NAT doesn't work for me because I use a /29 IP block on the LAN side.
It's strange when I activate the router mode and reboot the router, the configuration is still in router mode but My client shows up with the IP Adress from the WAN interface and not it's own public IP.
If I unselect and select the router mode, the IP adress is then correct but the speed is terrible slow.
Gold
Michael,
How does using /29 affect One-to-One NAT? I'm thinking it should work just as well as a /24.
How many public addresses do you have?
- Marty
I have one public IP on the WAN Interface and I will use a PUBLIC /29 on the LAN side:
in example:
3.4.5.6/30 on WAN side
3.4.6.0/29 on LAN side
and the client on LAN side should be visible with the LAN IP's:
3.4.6.1 and 3.4.6.2.
Gold
Re: RV180 slow in router mode
Michael,
Use One-to-One NAT to translate the external IPs to internal IPs.
Firewall-> Advanced Settings-> One-to-One NAT
Private Range BeginPublic Range BeginRange LengthService
192.168.1.100                                   3.4.6.1                                              2                           Any?
That will translate 3.4.6.1 to 192.168.1.100 and 3.4.6.2 to 192.168.1.101 and forward all traffic accordingly.
You can also use a Range Length of 1 if you don't wish to use consecutive LAN IPs.
- Marty
Hmm sorry that's not working
The real example is:
WAN IP: 86.245.121.126/29
LAN IP of Router: 86.245.121.249/29
Client in the Network behind has LAN IP 86.245.121.250
If I now configure NAT I got these errors:
Public IP should not be equal to WAN IP
or
Public IP Address should not be in LAN Subnet
Gold
Michael,
It is not working because you have a WAN IP configured on the LAN. You should use LAN IPs on the LAN side and allow the router to translate the WAN IP to the LAN IP.
192.168.1.100                                   86.245.121.249                                           2                        Any?
- Marty
Bronze
That is strange to see it showing as router mode either way on the interface--but it just goes to show you how many bugs there can be in these things!
628
