08-19-2012 03:03 AM
I have a problem which is quite urgent
I bought 2 RV180 to setup a VPN tunnel between a remote site and central office
The VPN tunnel is established, I can ping from central office to remote site but browsing on that server fails.
Here is my Network setup:
Central Office:
RV180 LAN IP: 10.2.1.1
DHCP: 10.2.0.0/16
VPN Tunnel:
Local IP: 10.2.0.0/24
Remote IP: 10.3.1.0/16
Remote Site:
RV180 LAN IP: 10.3.1.1
DHCP: 10.3.1.0/24
VPN Tunnel:
Web Server: 10.3.1.51
From central office i can ping both 10.3.1.1 and 10.3.1.51
But fails when accessing through browser both 10.3.1.1 and 10.3.1.51
Result for using trace route from 10.2.1.1:
traceroute to 10.3.1.51 (10.3.1.51), 10 hops max, 40 byte packets
1 * * *
2 * * *
3 * * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
Seems the routing is not really working through the VPN Tunnel
Can anyone can lend me a helping hand? Thanks very much
08-19-2012 03:07 AM
Also post the routing table for 10.2.1.1
Kernel IP routing table
Destination | Gateway | Genmask | Metric | Ref | Use | Interface | Type | Flags |
127.0.0.1 | 127.0.0.1 | 255.255.255.255 | 1 | 0 | 0 | lo | Static | UP,Gateway,Host |
192.168.1.0 | 0.0.0.0 | 255.255.255.0 | 0 | 0 | 0 | eth1 | Dynamic | UP |
192.168.1.0 | 192.168.1.144 | 255.255.255.0 | 1 | 0 | 0 | eth1 | Dynamic | UP,Gateway |
10.2.0.0 | 0.0.0.0 | 255.255.0.0 | 0 | 0 | 0 | bdg1 | Static | UP |
10.2.0.0 | 10.2.1.1 | 255.255.0.0 | 1 | 0 | 0 | bdg1 | Static | UP,Gateway |
127.0.0.0 | 0.0.0.0 | 255.0.0.0 | 0 | 0 | 0 | lo | Dynamic | UP |
0.0.0.0 | 192.168.1.1 | 0.0.0.0 | 0 | 0 | 0 | eth1 | Dynamic | UP,Gateway |
192.168.1.144 is the WAN IP of the RV180, I am puting the RV180 behind another router for testing
08-21-2012 07:12 AM
Hello Yuk,
The configuration seems bit confusing. Per your note above, on the local RV180, you have LAN IP of 10.2.1.1/16 and on the VPN tunnel, you have configured
On the remote RV180, you have LAN IP of 10.3.1.1/24 and on the VPN tunnel, you have configured:
Can you please verify these to be correct? Also, please attach the screenshots from both RV180 VPN configuration (both IKE policy and VPN Policy) for us to verify the settings.
Nagaraja
08-21-2012 07:44 AM
Hi Nagaraja,
Sorry as it is working now, just some stupid problems I did.
But now I have another issue on PPTP VPN,
I can connect using pptp by both Mac and Windows
After connected, I can browse the admin page of RV180 or other web server
When I try to use a network drive and starting download a file, the download start a few KB,
then the connection can no longer download anything, not even ping any device nor the admin page of RV180
Could you please advice is there any settings I can make to at least support a usable PPTP connection =.=
My RV180's firmware is 1.0.1.9
Thanks & Regards,
Ng Yuk Man
08-23-2012 12:55 PM
Hello Yuk,
The problem you are referencing might need a closer look from one of our SBSC Engineers. Can you please reach out to our SBSC center and open a Service Request for us to further review the issue?
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
Nagaraja
