RV180 / VPNClient Firewall Settings
I just purchased and installed the RV180 at my office.  One of my clients requires that I use Cisco VPN Client to connect to their systems.  Before I installed the RV180, everything worked just fine.  After I installed the RV180, the VPN client disconnects after 5 to 15 minutes, every time.
What firewall settings on the RV180 do I need to enable/disable so that the VPN Client can work w/o disconnecting?
The RV180 is the router at my office.  The VPN Client is on my computer, and I'm connecting to a client's system w/the VPN Client.
1 REPLY
Re: RV180 / VPNClient Firewall Settings
This is the message I receive when it disconnects.
        If I use my iPhone tethering connection (instead of the office internet), the VPN works fine, just like it did before I installed the RV180.
1094
