07-18-2013 10:46 AM
HI, just connected a remote control via wireless to my RV180, however fail to control it on VPN tunnel while no issue if it was connected with wired LAN, is there any setting is required ?
07-18-2013 10:52 AM
Hi Joseph, what kind of wireless are you using? Like a Verizon Hotspot or something? This may be very relevant. Also, whatever wireless connection is servicing for a LAN IP? Is it different than your RV180? What is your download/upload speed on the wireless connection? What kind of VPN do you use? IPsec or PPTP? What client? QVPN or something else?
-Tom
Please mark answered for helpful posts
07-18-2013 11:08 AM
Hi Tom, thank you for your response, basically it was ReyEye IR controller with PPTP connection, very strange, it is abled to ping while not able to connect it. I am using HK boardband & it should no restrictions, up/download is arround 30mb. There is no issue on all the LAN device connection, i wonder LAN & wireless are connected with difference valn in RV180.
