05-09-2014 03:51 PM
Need some assistance....
I was able to configure these routers using static IP's without any issue on my inhouse network.
Client doesn't want to pay for Static, so have setup DYNDNS account.
so have setup advanced IPSEC with FQDN
getting initial handshaking so they are seeing each other, but Tunnel does not establish.
from log get error on PHASE 1
"invalid sa protocol type 0"
Any suggestions, or documents I should be looking at to get the IPSEC VPN established.
Thanks in advance.
Simon
05-09-2014 05:17 PM
Duplicate posts.
Go here: http://supportforums.cisco.com/discussion/12200576/rv215w-ipsec-vpn-tunnel-rv180w-using-fqdn
05-10-2014 07:36 PM
Try putting in the dyanmic IPs as static and see if that works. If so, then you at least know it's something related to the FQDN/Dyndns setup.
