I'm setting up a number of new RV215Ws. I've set up the first one and saved the configuration.
Now I'm trying to upload that same configuration into another unit.
I see a very brief "running" bar like one would expect. But it only lasts a brief time (2-3 seconds) and then nothing else happens. No reboot, nothing more. The configuration is NOT changed. If I reboot the router or power cycle it, the configuration is NOT changed.
I've not encrypted the file.
Is this transfer sensitive to:
- the login that's set?
- the filename of the configuration file (I've changed the name and not the extension .cfg)
I need a "next step" here.
