RV220W and Port Forwarding
i have a Problem with my Cisco RV220W with the Firmware 1.0.3.5
I have in my LAN a Dreambox with the IP Adress 192.168.1.230, he listen to the Port 8880.
How can I set up a port forwarding from the WAN to the Dreambox ?
Michael
1 ACCEPTED SOLUTION
Gold
Hi Michael,
Thank you for posting. Please follow the steps below to forward the port to your Dreambox:
  1. Log into the router and browse to: Firewall-> Access Control-> Custom Services.
  2. Press "Add" and type Dreambox for the name, TCP for type. The Start Port and Finish Port will be 8880. Press "Save".
  3. Browse to IPv4 Firewall Rules and Press "Add". Use the following settings:
From Zone: Untrusted (WAN)
To Zone: Trusted (LAN)
Service: Dreambox
Action: Always Allow
Source Hosts: Any
Send to Local Server (DNAT IP): Type the LAN IP address of the Dreambox device here (i.e. 192.168.1.150)
Ignore other settings on this page and press "Save" at the bottom. You should now be able to reach the Dreambox from the internet using :8880
Please let us know if this works or if you need further assistance.
Gold
Hi Michael,
Service: Dreambox
Source Hosts: Any
Thanks it is working !
2063
