RV220W - losing connectivity between clients, static IP required
premsupp59
My office is set up with RV220W.   Funny thing is that all the client applications (referring to few different applications product) is unable to find the server.  But i can access to the server shared folder.
After trying out all possible methods.  I give a try to reboot the router, while the connection is at "limited connection" my application can access to the server.  Once connection is stable, again same problem.
I give another try by input a static IP in the client, it works well.  Once i take out the static IP, problem come again.
And there is no changes done in the router when this incident happen.
anyone, please help.
8 Replies 8
Brian Ng
Hi Premsupp59,
Has this been happening since you installed the device or is it something that recently happened? Does any of the clients get the correct DHCP information? From the information that you gave, I would assume that DHCP server is not working properly. I would save a back up of the RV042 configuration file and then do a factory reset on the unit and test it with just configuring the router to be in the same subnet as your server. Also, make sure that you try to eliminate other possibilities by plugging in the server and one PC directly in to the RV220W to test if possible. I hope that helps.
There is no installation and any special incident.  Yes.  I check the client is getting right DHCP.
I try to reset to factory default and upgrade firmware.  Both my notebook and server is connect to the router.
When the connection is limited, there is no issue.  Once the connection is up, the issue comes in.
And I have to input the static ip into the notebook.
And this happen to a few PCs, while a few PCs are working fine.
Please help
I am still not quite sure what is the root cause at this time. You could possibly have two DHCP servers in your network as you said some PCs work and other PCs do not work. Do you know if your server is also a DHCP server? You can verify that by turning off the DHCP server on the RV220W then reboot the RV220W. Now check to see if any of your devices are getting DHCP. Also, please verify that your default gateway on your server is set up correctly.
I did that .  I turn off the DHCP server setting to none.  My devices are not getting the IP address.
Yes the gateway is set up correctly.  Not possible to have 2 DHCP server.
example.  Now my device that is having the issue, I did a IP config to check on the ip address.  I manual input into the TCP/IP4 with the same IP.  It works.  Once take out the manual input.  The issue comes.
Okay, thanks for the update. Is this issue only happening when you are accessing your server or does it affect anything else that you do in the network? You mentioned that the issue does not happen when the PC are in limited connectivity? If so, does that mean the PCs are without internet when you can access your server? Also, did you configure anything on the RV220W when you did the firmware upgrade and then the factory reset?
I am able to access to shared folder.  But 2 different brand software are affected where we are not able to login due to unable to find the database that is in the server.
As it involve 2 different products software, we left out the possibility of the software issue.
Yes.  During the reboot, while it is in the limited connectivity status.  the software has no issue.
No configuration done during this time.  We did a firmware upgrade and factory reset to see it will resolve the issue.  But seems no help.
Thanks.
Is the laptop and server on the same vlan?
Verify the arp table for the server ip on the laptop when it's working and when it's not working.  Make sure it's pointing to the same MAC address under both conditions.
Is ipv6 enabled on any of the devices that are experiencing the problem?
I have occuring same issue in RV042.I set it everything with the exact detail through ISP (System Getting Perfect IP address which one we set on the router), Connection still limited and internet is not working. Already check With mannual IP configuration on that system but it’s not work. This is my newly purchased router 2 days back. It is happening with whole Network in my setup.I have only one DHCP server in my network. If I connect one system directly from ISP with the static IP address  it’s working but via router it’s not.
Suggest something ASAP .
Hemant
9266365225
