rv220w many problems with it
first problem : VPN tunnel was working fine with an rv042, then it stops working.I didn't changed the configuration. i connect another router and the VPN tunnel works right away!
second tunnel : i've update the firmware to the latest version 1.0.3.5 but i had many problem with the interface, specially with the vlan isolation. So i went down to 1.0.1.0
should i do an RMA ?
  • Small Business Routers
1 REPLY
Silver
NO you shouldn't need an rma, I do believe they are releasing new code for vlans port/802.1Q tagging in next firmware release but no issues with ipsec tunnels so if you need assistance with this call into support center and open a support case so we can take a look at your settings.(1-866-606-1866) -
Jasbryan
1240
