hp
RV220W: Portforwarding collides with IPSec
Hello
I have a setup with 2 RV220W at 2 locations.Both with the latest Firmware (1.0.3.5). I configured portforwarding for RDP at one site. Works perfekt. I also configured an IPSec VPN between the 2 sites. Works too.
Configuration overview:
Site_1:
- IPSec VPN to site_2
Site_2:
- IPSec VPN to site_1
- Port forwarding for RDP to a local server (server_2)
My first problem is that i can ping server_2 through the VPN from a pc within site_1 but i can not access this server via RDP. As soon as i disable the Portforwarding for RDP at site_2, RDP via VPN works!
I assume, that the RV220W mixes up portforwarding and VPN.
I tried to set up an additional firewall rule at site_2 allowing the traffic between the local networks of both sites without restrictions and place this rule at toe top.
But here is my second problem: I can not add any destination network to the firewall settings (firewall-->access rules). I only allows me to define a host to redirect the traffic to.
Are there solutions to this problem?
Kind regards
Hans-Peter
I am having this same issue. Were you ever able to find a resolution?
Have you tried the latest firmware?
The release note of firmware 1.0.4.17 shows a similar issue was resolved with firmware 1.0.4.17.
CSCtw50531: Fixed an issue in which an IPSec VPN peer could not access
the web configuration utility if port 80 was forwarded.
I am running the new 1.0.4.17 firware and still experiancing the same issue reported above.
869
