New Firmware available for RV340 Series Router family! This includes the RV340, RV340W, RV345, and RV345P
To learn more and get the latest Firmware version click here.
Community Member
RV220W - Setting Up VLANs Help
I am new to VLANs and wanted some feedback as to how I have the router set up prior to deployment.  I have 5 VLANs set up as follows:
VLAN ID
DescriptionInterVLAN Routing
Device ManagementPort 1
Port 2
Port 3
Port 4
1DefaultEnabledEnabledUntagged
Untagged
Untagged
Untagged
Office
Disabled
Enabled
Tagged
Tagged
Tagged
Tagged
3USDA
Disabled
Enabled
Tagged
Tagged
Tagged
Tagged
4Cameras
Disabled
Enabled
Tagged
Tagged
Tagged
Tagged
5Guests
Disabled
Enabled
Tagged
Tagged
Tagged
Tagged
The USDA and Cameras VLAN will be on the same port with an unmanaged switch (I was planning on using MAC filtering to differentiate) and the Office VLAN will go to another unmanaged switch (using MAC/IP reservations here), the Guests VLAN was going to be used for the Guest Wifi only, keeping this completely seperate from the other networks.
Is there a better way to configure or do I need to make any further adjustments?
Any help is greatly appreciated!
Fireman1224
1 ACCEPTED SOLUTION
Community Member
Hi Dwight,
I don't see why you would need that other router as you still have Port 4 you could use ( based on what you've written above)  for the USDA VLAN.  If the device on the USDA needs to be reached externally a DMZ would probably be the best bet.  Otherwise this looks fine assuming those two different office ports are only connected at the RV.  Yes it is a good idea to exclude any VLANs on interfaces you don't want them on.
-Trent Good
** Please rate useful posts! **
-Trent Good ** Please rate useful posts! **
Community Member
Hi Dwight,
You may want to look into VLAN Tagging.  On the RV Device( and in general) you can only have 1 untagged VLAN per interface.  In order to transfer multiple VLANs you would need a trunk with 1 untagged VLAN and 1 tagged VLAN which is as you have configured now.  However, unmanaged switches don't recognize tagging.  Therefore, all tagged traffic will probably be dropped.
You will need to have either 1 unmanaged switch for each VLAN or plug multiple interfaces from the RV into an unmanaged switch(this is a bad idea as it will cause security issues).
Also, if you have a managed switch you can use just one interface from the RV to transmit multiple VLANs.
-Trent Good
Community Member
Ok, using two unmanaged switches to support the office computers and an office wifi SSID, running a separate line for the camera system, running a separate line for the USDA computer, and associating the Guest VLAN only to the Guest wifi, how would you configure the VLANs? Or do I have it basically set up correctly?
Thanks for the help!
Community Member
Hi Dwight,
If you only have one PC that you want on the USDA VLAN than you can run a line straight from the RV into that PC.  However, if you want to be able to reach the USDA from the office I would enable inter vlan routing.
I would have the following configuration:
Port 1 as an access port has Office VLAN 2 Untagged(PVID). (this connects to an unmanaged switch for office items.)
Port 2 as an access port has USDA VLAN 3 Untagged(PVID). (connects directly to USDA Computer)
Port 3 as an access port has Camera VLAN 4 Untagged(PVID). (connects to an unmanaged switch for cameras.)
Than on the same page assign the Guest SSID for VLAN 5 Guest.
If you have an office VLAN I would assign the SSID for the Office VLAN 2.
Let me know if you have any further questions!
-Trent Good
Community Member
Thanks for the advice!
I am going to set it up as described, except I am going to eliminate USDA. There was an additional router at the location, so I am going to use this as another LAN attached to the remote switch to act as the USDA VLAN. Also, we will run another cable directly to the router, as you suggested for the cameras. Do you think I should place the second router in the DMZ on the RV220W? Just a thought, but don't want a security hole either being that it is just a Dlink DIR-615.
In order to designate the ports properly, do I need to exclude the ports not associated with the VLAN? For example:
VLAN ID - 1
Name - Office
Port 1 - Untagged (going to switch for office computers)
Port 2 - Untagged (going to remote switch for other office computers)
Port 3 - Excluded
Port 4 - Excluded
VLAN ID - 2
Name - Cameras
Port 1 - Excluded
Port 2 - Excluded
Port 3 - Untagged (New cable to be run)
Port 4 - Excluded
Thanks again!
Community Member
Hi Dwight,
-Trent Good
Community Member
Re: RV220W - Setting Up VLANs Help
Trent,
Thanks so much for your assistance!
I only have enough cable to run one more line, that's why I used the Dlink router. I need to run the Cameras off of the router on a separate VLAN, then configure it for remote access. I don't really care about the USDA computer, so being outside the firewall (DMZ) is not of my concern, I just didn't want to create a security hole for our network.
Thanks again!
Dwight
1121
