RV320 Bandwidth Management issue
we use RV320 (firmware v1.1.0.09) since 2 months as Dual-WAN-Gateway in Load Balance Mode :
WAN-1 – TV-cable with 6 Mbit/ 100 Mbit (up/down);
WAN-2 – ADSL 600 Kbit/ 6 Mbit (up/down).
We need ADSL for some VPNs because the TV-cable provider can't supply us with a static IP.
The QOS settings are simple : rate control - min / max rates for up / downstream.
We have following bandwidth settings  :
WAN1 Upstream min 500 Kbs max 5000 Kbs
WAN1 Downstream min 5000 Kbs max 50000 Kbs
WAN2 Upstream min 80 Kbs max 500 Kbs
WAN2 Downstream min 500 Kbs max 5000 Kbs
The problem is – the rv320 uses WAN2-bandwidth limitations  for WAN1 too !
Is this a bug or feature ?
Best regards.
710
