10-06-2014 12:11 PM
Hello!
Three bandwidth management related questions, if I may...
1. If you add multiple bandwidth rate control rules (e.g. for different subnets or services) why do you get an error if the sum of the max limits exceeds the total WAN rate? That makes no sense to me as the max is a limit not a guarantee.
2. If you set up a rule like:
WAN1 All Traffic [TCP&UDP/1~65535] 192.168.1.1~192.168.1.254 Downstream 2000 8000
Will this provide a guaranteed 2 Mb/s and limit of 8 Mb/s to each IP on in the 192.168.1.0 subnet, or will the guarantee/limit apply to the entire subnet?
3. If the answer to question 2 is "subnet", the is there any way to cap each DHCP LAN client bandwidth without creating a rule for each IP in the range (this is not practicable, due to the issue raised in question 1).
My confusion is also somewhat due to the following statements found in the router's own help content under the "Bandwidth Management" section:
and a statement in a specific KB article on Bandwidth Management Configuration on RV320
I assume there is a mistake in the explanation of max. rate. Should it not say "limited bandwidth" instead of "guaranteed bandwidth", to be consistent with the explanation of rate control?
Secondly, in the rate control explanation, it says the min and max apply to "each service or IP address", but then the statement from the KB indicates that any traffic meeting the criteria is subject to rate control. The former indicates that you can guarantee/limit the bandwidth per client (IP address) on the LAN (what I want to do), the latter suggests something different.
I hope someone here can help clarify all this, thanks!
07-15-2015 08:12 AM
I recently installed an RV320 in my home office.
I have the same experience as you describe in #1 above. That is, the 'Max Rate' using 'Rate Control' behaves as a guaranteed rate, rather than a limit.
This goes counter to my experience with other QOS rate control systems - where the 'Min Rate' is the guarenteed rate, and 'Max Rate' is the limit. For example, I would expect to be able to configure the following:
Max Bandwidth Provided by ISP
Interface Upstream DownStream
WAN1 1500 1500
Rate Control Table
Interface Service IP Direction Min. Rate(kbs) Max. Rate(kbs)
WAN1 All Traffic 192.168.1.100 Downstream 500 1500
WAN1 All Traffic 192.168.1.101 Downstream 1000 1500
The expected behavior is that either IP host could achieve up to 1500kbs when the link is uncongested. However, if both hosts were competing for the link, the first host (..100) would get 500kbs, and the second (..101) would get 1000kbs. That is, the sum of the ‘Min. Rate’s (guarenteed rates) cannot exceed the IPS link rate (1500kbs).
The RV320 will not allow this configuration, as the sum of the ‘Max. Rate’s exceeds the IPS link. The downside to having the ‘Max Rate’ being the guaranteed rate, is bandwidth cannot be shared amount rules in the table (IP hosts) when the link is uncontested.
09-17-2016 03:34 PM
FYI seems to be fixed in firmware 1.3.1.12, see note from changelog:
Bandwidth Management Rules limit sum of Max Rates to ISP Max BW
(CSCut04618)
