RV320 EasyVPN - No LAN access
Recently changed equipment from an ASA5505 to the RV320 (not happy with the move) due to a necessity for the dual WAN option. All has been well until I went to configure the VPN. I'm using the EasyVPN option, all settings match our previous VPN setup (tunnel name, password, interface) and the connection to the VPN works, however there is no way of accessing the LAN, no SSH, no RDP, no intranet, etc. The only thing that does work is the access to the internet.
Summary page shows a Virtual range of 40.10-40.50 and a local group of 10.0/24.
Any help? What am I missing?
Hi Jlink,What is the ipconfig
Hi Jlink,
What is the ipconfig on the workstation when connected? you can also try tracert [ip address of the remote host] to see if the traffic actually goes via VPN.
Aleksandra
Also, you’ll want to be sure
Also, you’ll want to be sure to secure your VPN authentication beyond just a password using a shared secret between your VPN client and the server. There is a 3rd party integration that will do that.
222
