RV320 ipsec on VLAN
Hello
I have a working ipsec lan to lan tunnel, but it's only works on default vlan
changing the local security group IP to the corresponding VLAN is not working, VPN phases are OK, but traffic is blocked because of the wrong VLAN
I doesn't seem to be possible to set the IPSec VPN profile to bind a particular VLAN
Tunnel is working as expected with different local groups, but only on default VLAN
It would be great to have a VLAN# tick box on the VPN profile edit form
maybe you have a hint or warkaround?
11
