RV320 problem with VPN connect (BUG)
forgive for bad English
Today I bought and I adjusted RV320, at once I saw some problems.
Firmware last
1. I adjusted two VPN tunnels between RV320 and two RV-082
also I saw what not one tunnel in Web panel not connect.
I many times pressed, the condition didn't change!
Having made Ping on 192.168.1.1 computers in a network 192.168.1.0 I saw answers:
it is simple a miracle or huge BUG.
2 The second BUG, VPN tunel No. 2 doesn't work in general as don't kick. And before there was RV-042G and RV-82 and everything was OK
From log:
2013-08-29, 21:47:28VPN Log[g2gips1]: cmd=down-client peer=78.31.177.145 peer_client=192.168.2.0/24 peer_client_net=192.168.2.0 peer_client_mask=255.255.255.0
2013-08-29, 21:47:28VPN Logip route del 192.168.2.0/24 via 178.216.123.65 dev eth1 metric 35
2013-08-29, 21:47:28VPN Logiptables -t nat -D vpn -s 192.168.0.0/24 -d 192.168.2.0/24 -j ACCEPT
2013-08-29, 21:47:28VPN Logiptables -t nat -D vpn -s 192.168.2.0/24 -d 192.168.0.0/24 -j ACCEPT
2013-08-29, 21:47:28VPN Logiptables -t nat -D vpn_postrouting -s 192.168.0.0/24 -d 192.168.2.0/24 -j ACCEPT
2013-08-29, 21:47:28VPN Logiptables -t nat -D vpn_postrouting -o eth0 -s 192.168.2.0/24 -d 192.168.0.0/24 -j ACCEPT
2013-08-29, 21:47:37VPN Log[g2gips1] #14: [Tunnel Established] sent MR3, ISAKMP SA established
2013-08-29, 21:47:38VPN Log[g2gips1]: cmd=up-client peer=78.31.177.145 peer_client=192.168.2.0/24 peer_client_net=192.168.2.0 peer_client_mask=255.255.255.0
2013-08-29, 21:47:38VPN Logip route add 192.168.2.0/24 via 178.216.123.65 dev eth1 metric 35
2013-08-29, 21:47:38VPN Logiptables -t nat -I vpn -s 192.168.0.0/24 -d 192.168.2.0/24 -j ACCEPT
2013-08-29, 21:47:38VPN Logiptables -t nat -I vpn -s 192.168.2.0/24 -d 192.168.0.0/24 -j ACCEPT
2013-08-29, 21:47:38VPN Logiptables -t nat -I vpn_postrouting -s 192.168.0.0/24 -d 192.168.2.0/24 -j ACCEPT
2013-08-29, 21:47:38VPN Logiptables -t nat -I vpn_postrouting -o eth0 -s 192.168.2.0/24 -d 192.168.0.0/24 -j ACCEPT
2013-08-29, 21:47:38VPN Log[g2gips1] #15: [Tunnel Established] IPsec SA established {ESP=>0x102b2557 < 0xc23b7d0f}
What problem i'm undersdund.
3 The third BUG, adding or changing VPN tunnels, against for a second there is a form for addition of the new tunnel, why it? ? ?
Everyone's tags (4)
1 REPLY
Re: RV320 problem with VPN connect (BUG)
A little later...
I solved reset all settings to default and to adjust from scratch, all work.
What is done? I don't understand.
2066
