RV320 to RV320: Is it possible to Load Balance using two VPN's?
Dear support community:
We're on a lab setting connecting two Cisco RV320 routers together via their WAN ports. We have one VPN Tunnel up and running, but we're wondering if there's any way you could connect a second VPN tunnel to the same remote LAN and do Load Balance between both connections.
We know it's possible to have a second VPN tunnel as backup, but we're not able to configure load balance between two tunnels.
Thanks in advance!
Everyone's tags (5)
1 REPLY
Gold
Juan,
The router should show an error if you try to connect a second tunnel to the same LAN segment, making Load Balance impossible. Is that what you are seeing?
- Marty
229
