02-23-2014 05:05 AM
I’m about to join the Cisco family by buying a RV320.
But I haven’t find out if it can fulfil my needs, my old ASUS router can forward a request coming in from the WAN-side on a specific port (e.g. 800) to a IP-address AND different port on the LAN-side (e.g. IP 192.168.1.50 port 500).
I as fas as I can understand this not possible on the RV320,It can just forward the incoming port to a IP-address on the LAN-side but always same port.
I have read manuals and tested Emulator and can not find out how to configure to make this happen
Is there a solution to this?
Thanks in advanced :-)
Solved! Go to Solution.
02-23-2014 01:41 PM
Hello Christer,
The following link may help you with your requirement.
Nagaraja
02-23-2014 01:41 PM
Hello Christer,
Nagaraja
