RV325 DHCP Pool Limit
Is it possible to have a dhcp pool larger than 50 ip addresses in the RV325 (firmware 1.1.1.19)?
Everyone's tags (1)
1 ACCEPTED SOLUTION
Assuming your using the RV325
Assuming your using the RV325 as the DHCP server, yes, you need to go into the DHCP Server setup page and amend the start, finish, or both IP addresses to make the pool as big or small as you require.
Thanks portisheadradio. I was
Thanks portisheadradio. I was overlooking IPs reserved for VPN that needed to be moved.
106
