01-12-2018 11:59 AM - edited 03-21-2019 11:02 AM
We purchased two RV340 routers. I've been getting this warning message in the logs:
dnsmasq: ignoring nameserver 127.0.0.1 - local interface
Is this something I should be worried about?
01-21-2018 02:52 PM
I'm not worried about it, but if you've configured the router to email logs, it's seriously annoying. I had to set turn off the 'Network' checkbox, but now I have NO idea what messages I might miss.
Firmware version 1.0.01.17 -- Don't know if this is a new issue, I just installed and upgraded the router today.
06-05-2018 11:13 PM
Hi, i have the same problem with rv340, firmware 1.0.01.18. Why they don't squash this bug?? It's very annoying to get several lines this warning in e-mail log: (<warning>dnsmasq: ignoring nameserver 127.0.0.1 - local interface)
Please fix it!
06-06-2018 10:00 AM
I see this also in the logs. I am not sure what it means. Something about a loop back with DNS. Is it a real problem?
06-21-2018 06:47 PM
Any chance this is an DNS rebinding attack?
06-21-2018 10:48 PM
My name is Iliya Gatsev from Cisco Technical Support Team.
In case you are using latest firmware
1.0.1.18
and after upgrade and reset to factory settings, this issue is still present, it will be good to call our support line and open a support case so we can track this issue.
https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Iliya Gatsev
Cisco STAC Network Engineer
Together we are the human network .:|:.:|:. CISCO
06-22-2018 03:31 AM
06-30-2018 12:50 PM
@Iliya GatsevIs this being looked at?
This essentially invalidates the (only 4K) log buffer, because if you want to track any network tagged issues (this is a router...), it quickly fills the buffer (takes about 2-3 hours, for my config, about 96% full of JUST these errors).
Sure, I could set up a SysLog, or email alternate, but really this should get resolved properly, or provide a filter mechanism that's keyword-based, instead, so the log space isn't overflowing constantly?
Obviously this is more of a home-user issue, but even a SMB IT dept. doesn't want to wade through hundreds of thousands of bogus warnings, or store them, for that matter...
08-04-2018 06:11 AM
I also have this problem with RV340 - this makes syslog completely useless, as it is flooded with this error. Please fix ASAP
06-24-2019 07:16 AM
Hi, I have the same problem with the RV260W, and I already have the lastest firmware ver. 1.0.00.15
Is annoying continue reciving this warning message,
any solution?
thanks!
08-07-2018 05:55 PM
I believe I had this same problem and a google search came up with an issue with buggy Samsung TVs on the network. The fix was to create a dhcp reservation for the TV and give it a name. I no linger see these errors. Just gotta figure my firewall errors now.
My router was also locking up before too and hasn’t since making this change.
01-04-2019 08:03 AM
I had the same issue and the router locked up very often and had to be rebooted. Cisco TAC advised me to upgrade the firmware to the latest version, 1.0.02.16, and then factory default the router.
I have completed the procedure and the error message has disappeared.
I was previously receiving the error message a few times every minute.
The router is now running for a about an hour and I have not seen any of the messages thus far.
01-07-2019 12:42 AM
Upgraded to latest fw. 1.0.02.16. I’m still getting same log messages, but not that frequently. So the reason for these log lines remains unresolved...
And when i get the log e-mail it’s full of this very same log-line, doesn’t include any other information.
I had done the factory reset many times, and again after this latest firmware upgrade. I have made static ip addresses for all of my devices in dhcp and named them.
So, weird problem, that’s all i can say...
01-07-2019 04:50 AM
01-25-2019 09:08 PM
@dharric123 Did you ever get a response, to your ticket?
To the Cisco employee, who responded some time ago, can you please update us?
I also get 2-3 hours of logs, before it overflows the 4k queue, making logging essentially "useless".
Can SOMEONE please at least get some type of response from a Cisco source (I'm using this as a home unit, and do not have an account, to open a ticket).
I'm no senior-IT guy, but I generally know my around most common networking, packet transitions, tagging, security models, that kind of things (I'm more of an OS guy from the device-side, and s/w, but my strengths lie in Graphics and Storage, and to a less extent, bus architecture, network devices are close to the end).
Even a way to exclude this specific warning, without disabling all warnings/network log lines, would be better than the current state.
Thanks, for anyone who can provide some update to this.
