Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
RVI042 - max # of vpn gw to gw tunnels supported?
What is the max # of vpn gw to gw tunnels supported? What would you recommend for the remote router - 1 user/ 1 phone? Cable modem, most likely.
1 ACCEPTED SOLUTION
Re: RVI042 - max # of vpn gw to gw tunnels supported?
RV042 supports 50 Gw-2-Gw tunnels. As for the remote sites, you could consider WRV210 for its Wi-Fi, VPN, and lower cost. However, using RV042 in a remote site provides an option for redundant internet connection.
1 REPLY
2006
