New Firmware available for RV340 Series Router family! This includes the RV340, RV340W, RV345, and RV345P
To learn more and get the latest Firmware version click here.
Community Member
RVL200 - Port Forwarding Issue
HI There
I have an RVL200 upgrade to firmware 1.1.10.1 so I can port forward into other subnets from the WAN. (1.1.7.1 allows only primary subnet).
Multiple subnets are configured, as are static routes to the next hop.
However, it does not work. If I have port forwarding on, either to the local or other subnet, the router is not forwarding packets. This is confirmed by a portmirror/wireshark capture on the routers LAN port.
The router can ping/reach the destination.
I did turn off DHCP (the RVL200 manual says something about it).
Any ideas?
I have thought of trying to find 1.1.8.1 or 1.1.9.1 to use, as the feature came out in 1.1.8.1, however 1.1.10.1 provides Vista 64bit support, so I'm kind of rock/hard place.
Perhaps this new version??? comming out ??? that adds Win 7 support will also have some other fixes/enhancements?
I plan to call support, but I wanted to ask in the forum first.
-Henry
Silver
Re: RVL200 - Port Forwarding Issue
What are you trying to forward?  Did you have this setup with another type of router and have it working?  Can you post the screenshot of the packet capture you have to better clarfy your issue?  And can you possibly send a screenshot of your portforwarding you have setup on your router, this will help determine the issue your having?  Thank You.
Community Member
Thanks David for asking!
I was able to (after a few reboots, and a clearing of the routing table) to get this working.
The one thing about the .10 firmware is that things seem to need hard reboots a bit more often..
I am however eagarly awating when I can connect from Win 7 64bit to the SSL VPN.
-Thanks,
Henry
2187
