S2S vpn design
I want to ask , is it possible to create a site 2 site vpn connection between a ASA 5525 x and a Cisco RV 120 W
I ask this before we buy this RV120W, any other similar router sugestions are also welcome
All the reply is very welcome,
  • Small Business Routers
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hi FujifilmFCB,
Hi FujifilmFCB,
You can definitely configure a S2S between an ASA and a RV, you can take a look to this guide and let me know if you have any question:
http://sbkb.cisco.com/CiscoSB/GetArticle.aspx?docid=7200e3b590e443af8f27a1ca957705ba_Configuring_a_Site_to_Site_VPN_tunnel_between_RV_Series_Rout.xml
Hope this info helps!!
Rate if helps you!!
-JP-
Hi FujifilmFCB,
Hi FujifilmFCB,
Rate if helps you!!
-JP-
Thanks JP,
Thanks JP,
thats the document i was looking for
