New Firmware available for RV340 Series Router family! This includes the RV340, RV340W, RV345, and RV345P
To learn more and get the latest Firmware version click here.
Community Member
Selecting NAT IP from static range
Hi folks,
I have a SRP547W which I'm trying to replicate a configuration I had on an old Cisco 847 that recently died.
My ISP has allocated me a /29. The DSL configuration means that the IP address on the PPP session is assigned randomly. I have a mix of internal devices on a private IP range and a few devices with publically accessible addresses. All of the devices on the internal network need to be NATted to a public IP from the range allocated to me.
I can see that I can use the software or hardware DMZ to set up the servers, but I can't see any way to configure the external NAT address.
Any suggestions?
Aled.
Everyone's tags (6)
1 REPLY
Silver
Aled,
I'm guessing you are referring o setting up one to one nat , so mapping several public ip address to internal private if so the SRP547W doesn't support one to one nat operation. You can contact Cisco Small Business Support Center and open a support case for more information DATA SHEETS SUPPORT NUMBERS
Jasbryan
678
