08-26-2009 09:33 PM
How do I configure wireless security for a WRV54G router?
08-27-2009 06:53 AM
Take a look at the user guide. There is a section on wireless security.
http://www.cisco.com/en/US/customer/products/ps9923/products_user_guide_list.html
Hope this helps.
Brandon
07-08-2016 04:47 PM
It is easy to setup a Wi-Fi router in a very easy way. It is very simple to use the Wi-Fi connection in case your PC had 192.168.0.l a wireless network card. To be able to set up a wireless router, you should go along with the guidelines delivered by the router manufacturer. The actual recommendations are going to be presented in printed format plus in a compact disc. You can get the software via internet on top of that.
