Setting Up Dual Wan on RV082
Good morning,  I have a client that currently has two ISP's.  They are Verizon and Comcast and are both static addresses.  They are using the RV082 VPN/ Dual WAN router.  I followed the steps to set up dual WAN as a fail safe, once I unplugged the Comcast line, connection was completely lost.  I was wondering if a reboot of both the modem/ router is needed, when I go to the interface of the router, it seems like the router can't pull any of the information from the Verizon mode.  Please advise if possible.  Thank you.
  • Small Business Routers
1 REPLY
Hello Tim,
     Resetting the router would be a good idea, however make sure to save your configuration before resetting. Also, here's an article on Dual WAN, it may offer you some more insight into the process.
Configuration of Dual WAN with Redirection to Two Servers on RV042, RV042G and RV082 VPN Routers
Madison Carpenter
259
