Slow Internet Speed - RV042 v1.2
IT professional needs help with slow internet speed due to RV042 router:
Testing my interenet speed to determine bottleneck and it is my Lynksys RV042 Router.
     Summary:
          Cable modem only:                57.7Mbps DL speed
          RV042 and Cable modem         2.2Mbps DL speed
Equipment Details:
ISP: Comcast Cable "Blast" "Up to 50 Mbps"
Cable modem:
Cisco Model: DPC3008
DOCSIS 3.0
S# 241985600
Mfg Date: 11/2011
Lynksys Router:
Model: RV042 v1.2
S# NKS10095371
Mfg Date: 03/2010
Firmware 1.3.13.02-tm  (latest firmware that I could load)
Testing:
Connected Win 7 laptop directly to cable modem
Recycled power on cable modem
disabled/enabled laptop NIC
Speedtest.Net Results (average over 5 tests);
   Ping:  25ms    DL:  57.73Mbps   UL:  11.48Mbps
Powered off Cable Modem
Powered off RV042
Connected RV042 to Cable Modem
Connected Win 7 laptop to RV042
Powered up cable modem
Powered up RV042
   Ping:  25ms    DL: 2.2Mbps    UL:  10.7Mbps
Tried adjusting various RV042 configuration settings:
     Set bandwidth management to highest setting (100000)
     Disabled SPI & DOS
     Minimum Access Rules (Allow all LAN traffic/Deny all WAN traffic)
     No content filters
Changing these configuration parameters had virtually no effect on DL speed.
Everyone's tags (3)
1 REPLY
Testing Update:
Additional follow on testing last night:
Reset RV042 to Factory Defaults.
Set Router Parameters to what I needed.
Speedtest.Net:  Again very slow DL speed:  2.3Mbps
Rebooted cable modem.
Rebotted RV042.
Disabled/enabled laptop NIC.
IMPROVEMENT !
Speedtest.Net:  Ping:  25ms  DL:  32.0Mbs  UL:  10.7Mbps
Configured RV042 with for personal parameters
Rebooted cable modem, RV042, and reset NIC
But now I know it is someting within my configuration !!!
Backed config changes one at a time & retest each time.
Problem found!
I had set the ports to Full Duplex/100Mbs and disabled "Auto Negotiate"
Default is Auto Negocite enabled.
Enabled Auto Negotiate.
Much better than 2.2Mbps but much less than direct attach to the cable modem of 57.7Mbps !
Can't the RV042 come closer to the 57.7Mbps of the cable modem ???
I could see a 10% hit on performance due to router functionality, but not almost 50% !
2004
