SNMP - Not so "Simple"
I am somewhat new to newtworking and I was tasked with getting Solarwinds to communicate with all of our network equipment.  I have been able to get everything into Solarwinds and recognized but our ASA is not returning SNMP information.  I have been running a tool called getsnmp.exe and I can get a response from my workstation after adding my ip address into the asa host access list.  If I then add the SolarWinds server to the Host access list, snmp still times out.  If I try from another workstation and add it to the list, it also times out.  If I change the ip address to match my workstation address, snmp works.  I am utterly confused as to why it is only working with my IP address of my workstation.  Everything is on the same subnet.  Any help please?
1 REPLY
The firewall can be managed
The firewall can be managed via up sown pretty easily as a node.
as long as you enable
SNMP Host and the interface Poll Community
SNMP Host and the interface Poll Version
Once you get that going you will probabaly need to dig a little for the IKE OID's to check tunnel states.
or for number of connections etc...  It realy depends on your monitoring strategy.
Hope this helps.
Carl
146
