11-04-2011 05:54 AM
I have an SRP541W.
WAN1 is connect to a carrier requiring PPPOE.
The shows physical link up.
the log shows unable to complete PPPoE discovery
Any ideas
11-04-2011 06:20 AM
Hi John,
The physical link indicator just shows that the WAN Ethernet interface is running correctly - not the logical PPP session that runs over it.
To what are you connecting the SRPs WAN interface?
Do you need to configure a service name for your provider?
Does the PPP link remain down if you reboot the SRP?
Andy
11-04-2011 07:19 AM
PPP link remains down the interface just shows connecting?
I dont need a service name
The SRP Wan interface plugs into an rj45 supplied by carrier. The internet connection is a wimax radio link.
If I put the RJ45 into my laptop and setup a PPPoE dialer it works fine.
John
11-04-2011 07:51 AM
Hi John,
Could you raise a case for this with the Small Business Support Center please.
From your description, I would expect this to work. With a formal case open, we will be able to diagnose the problem and look for a cause if there is a defect.
Andy
11-06-2011 03:53 AM
I will log it tomorrow.
11-07-2011 04:34 AM
Case is open waiting on response
11-08-2011 07:03 AM
Small Business support resolved the issue.
Basically the MTU needs to be forced to 1492. Auto doesnt work
11-08-2011 12:32 PM
Thanks for sharing with the community John.
Andy
