New Firmware available for RV340 Series Router family! This includes the RV340, RV340W, RV345, and RV345P
To learn more and get the latest Firmware version click here.
Community Member
SRP541W PPPOE issue
I have an SRP541W.
WAN1 is connect to a carrier requiring PPPOE.
The shows physical link up.
the log shows  unable to complete PPPoE discovery
Any ideas
SRP541W PPPOE issue
Hi John,
The physical link indicator just shows that the WAN Ethernet interface is running correctly - not the logical PPP session that runs over it.
To what are you connecting the SRPs WAN interface?
Do you need to configure a service name for your provider?
Does the PPP link remain down if you reboot the SRP?
Andy
Community Member
SRP541W PPPOE issue
PPP link remains down the interface just shows connecting?
I dont need a service name
The SRP Wan interface plugs into an rj45 supplied by carrier.  The internet connection is a wimax radio link.
If I put the RJ45 into my laptop and setup a PPPoE dialer it works fine.
John
SRP541W PPPOE issue
Hi John,
Could you raise a case for this with the Small Business Support Center please.
From your description, I would expect this to work.  With a formal case open, we will be able to diagnose the problem and look for a cause if there is a defect.
Andy
Community Member
SRP541W PPPOE issue
I will log it tomorrow.
Community Member
SRP541W PPPOE issue
Case is open waiting on response
Community Member
SRP541W PPPOE issue
Small Business support resolved the issue.
Basically the MTU needs to be forced to 1492. Auto doesnt work
SRP541W PPPOE issue
Thanks for sharing with the community John.
Andy
918
