TFTP WITH WRV210
I have a WRV210 Router. I am unable to access the web interface but the DHCP Server for the router is operational. I have tried to reset to defaults but this does not work. I have also tried to upgrade the firmware and restore a configuration file via tftp but it times out. Please advise if there is another way to recover this router.
Re: TFTP WITH WRV210
Before you run the TFTP client, did you set your PC to have static ip address in the 192.168.1.x subnet, e.g. 192.168.1.100?
Yes I did all this already. I can ping the gateway ip address of 192.168.1.1 but i cannot tftp the backup image file for the router nor the firmware upgrade.
Well, you might need to call the Tech Support or your reseller for RMA if the device is still under warranty.
2813
