Unable to block port for second public IP using RV220W.
I am unable to block ports using access rules. Here is an example of a rule. I have set up blocks for all IP's, only the second IP, block SSH, block SSH-TCP, and block SSH-UPD. Port is still open. I even rebooted the device.
  • Small Business Routers
Hi, Access rules blocks the
Access rules blocks the traffic that is destined to the internal network..... not to the outside interface/wan interface ip address of the RV router..... you need to do something to block the ssh that comes to the box.
Karthik
Thank you. How would I do
Thank you. How would I do that then? I thought if I set the rule to always block it would block that traffic?
Does that mean that 1 to 1 nat is like a DMZ? All ports are open?
49
