Unable to connect VPNs RV320 to WRVS4400N
I had an RV220W router that died.  I replaced it with a RV320, but I'm unable to re-connect the VPNs to my office WRVS4400N's.  When I look at the log on the RV320 I'm not getting a lot of useful information, just [g2gips1]: [Tunnel Disconnected].
Is there a compatibility issue with the RV320 - WRVS4400N's?
I purchased a D-Link DSR-250 while I waited for the RV320 to arrive.  I can establish the VPN's to the WRVS4400N's with it, but the overall performance of the DSR-250 is lacking, hence the desire to put the RV320 into production.
Does anyone have VPNs between the RV320 and WRVS4400N working?
I tried IP Only, with IP by DNS Resolved, and the VPN connected.  As the address on the WRVS4400N is dynamic, will this mode reconnect on an address change?
9 Replies 9
mpyhala
Level 7
Level 7
For Remote Group Setup, try Dynamic IP + Domain Name (FQDN) Authentication. Do no use WWW. in your FQDN, it should be syntrak.ca only. If that fails, resolve the IP address and try IP Only as a test. If it works using only the IP address, your router may be having issues resolving DNS.
- Marty
Thanks for the input.
When I try Dynamic IP, it forces AGGRESSIVE MODE.  Even though I turn on AGGRESSIVE MODE on the WRVS4400N, the log reports:
 [Tunnel Authorize Fail] no connection has been authorized with policy=PSK+AGGRESSIVE
When I use the IP Only I was able to establish the VPN!
So, how do I resolve the DNS issue?  The Summary page shows the remote Gateway with the correct address when I use IP + FQDN.
Steve
Steve,
Dynamic IP always forces aggressive mode. Try leaving the WRVS4400N in Main Mode and see if that works.
- Marty
When I try without aggressive mode on the WRVS4400N, I get:
packet from 24.224.219.168:500: [Tunnel Authorize Fail] 'g2gips1' forbids connection, cause: Aggressive Mode
Steve,
As long as the WRVS4400N has DDNS, the name should resolve without issue when the IP changes. If possible, unplug the WRVS4400N for a while and when it reconnects, it should have a new WAN IP (depending on the ISP). The tunnel should come up.
- Marty
Thanks, I'll give this config a try.  My ISP only changes the address for that router about every 6-9months, so it will take a while to know for sure.
Steve,
I have cable and my IP changes very rarely. I have found that if I leave the router off for a few hours or overnight, I will get a new IP.
- Marty
For future reference, IP Only and IP by DNS Resolved is the correct way to configure the RV320/325, as well as the RV042(G), RV082, RV016 routers.
Dynamic IP + Domain Name (FQDN) Authentication will not work in this instance.
- Marty
