VPN between RV042 and Cisco 2801
HI
Kindly help me out. I'm configuring a p2p vpn between a cisco 2801 with IOS 12.3 and a linksys RV042. I'm getting following error on Linksys and Cisco respectively.
[Tunnel Negotiation Info] >>> Initiator Send Main Mode 1st packet
Dec 19 02:40:42 2011     VPN Log    Received informational payload, type NO_PROPOSAL_CHOSEN
dst             src             state               conn-id     slot    status
x.x.x.x       x.x.x.x   MM_NO_STATE          0        0       ACTIVE
Below are my config:
Linksys RV042:
Keying Mode: IKE with Preshared Key
Phase1 DH Group: Group2
Phase1 Encryption: 3DES
Phase1 Authentication: MD5
Phase1 SA Life Time: 28800
Perfect forward secrecy : enabled
Phase2 DH Group: Group2
Phase2 Encryption: 3DES
Phase2 Authentication: MD5
Phase2 SA Life Time: 28800
Preshared Key: xxxxxx
Cisco 2801:
crypto isakmp policy 11
encr 3des
authentication pre-share
group 2
lifetime 28800
crypto isakmp key xxxxxx address xxxxxx
no crypto isakmp ccm
crypto ipsec transform-set STRONGER esp-3des esp-md5-hmac
crypto map myvpn 10 ipsec-isakmp
set peer xxxxxx
set transform-set STRONGER
set pfs group2
match address 103
interface FastEthernet0/0
ip address 10.0.0.56 255.255.255.0
ip nat inside
ip virtual-reassembly
no ip route-cache
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
ip address xxxx xxxx
ip nat outside
no ip route-cache
duplex auto
speed auto
crypto map myvpn
ip nat pool branch xxxxxx xxxxx netmask 255.255.255.240
ip nat inside source route-map nonat pool branch overload
access-list 103 permit ip 10.0.0.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 110 deny   ip 10.0.0.0 0.0.0.255 192.168.2.0 0.0.0.255
access-list 110 permit ip 10.0.0.0 0.0.0.255 any
snmp-server community public RO
route-map nonat permit 10
match ip address 110
Rgards
SAM
Bump. Anyone sucessfully get past the "NO_PROPOSAL_CHOSEN" errors?
It looks like you are using the default hash for the crypto isakmp policy and that your connection is failing on the phase 1 negotiation.  The default hash on the crypto isakmp policy is sha.  On the 2801 try adding hash md5.
encr 3des
hash md5
group 2
lifetime 28800
Let me know if that helps.
Thank you,
Jason NIckle
1234
