Community Member
VPN connection between cisco 851and RV082
I am trying to set up a vpn connection between a cisco 851 router and a linksys rv082.  I have vpns setup between the rv82s but we are replacing them with the ciscos.
static ips
RV82
IKE with preshared key
IKE group 1, DES, MD5, PFS
IPSEC group 1, DES, MD5
Cisco851
crypto ipsec transform set
esp-des esp-md5-hmac
crypto kskmp policy
has md5
authentication pre-share
lifetime 28800
I am getting "Received information payload, type NO-PROPOSAL-CHOSEN" in the logs of the rv.  I am using CCP to configure the cisco.  VPN troubleshooting says tunnel is down but all other tests are ok.
1 REPLY
Re: VPN connection between cisco 851and RV082
Hi sklancaster,
As you can see it sure sounds like ISAKMP (i don't think ipsec at this stage), with the limited infomation you have given,  hasn't a agreed upon proposal between the two units.
It might be helpful to try debug crypto isakmp  command on the 851 to see where ISAKMP may be falling to exchange a agreed upon proposal.  It may be that the 851 is using  DH group 2 instead of the RV082 DH group 1.
I have got the RV042 working together with a ASA5505, just had to play with options to make sure the proposals for ISAKMP and IPSec were mutually agreeable.
regards Dave
2254
