New Firmware available for RV340 Series Router family! This includes the RV340, RV340W, RV345, and RV345P
To learn more and get the latest Firmware version click here.
Community Member
VPN connection to WRVS4400N using a Samsung Galaxy tablet
I have a Samsung Galaxy 10.1 tablet and have bee trying to connect to my WRVS4400N router with VPN through the "on board" software as well as with the Any Connect software from Cisco.  I have no issues at the moment using Quick VPN from my laptop.
When using the Any Connect software I receive the following messages:
Security warning: untrusted certificate
AnyConnect cannot verify the identity of <IP address>.  Would you like to continue anyway?
- Certificate does not match the server name.
- Certificate is from an untrusted source.
- Certificate is not identified for this purpose
[Accept]  [Details]  [Cancel]
If I select accept, the following error is received:
"Error:  Connection attempt has failed due to server communication errors.  Please retry the connection".
I have tried setting up the on board VPN with the Samsug Galaxy but every attempt has resulted in a time-out of the connection.
Any assistance would be greatly appreciated.  Thanks.
Community Member
Hi Blair,
The WRVS4400N only works with the QVPN software. The only small business router at this current time works with the Cisco any connect vpn is the SA500 series routers.
I hope this helps.....
Tori Woods
Cisco Support Engineer
CCNA, CCNA Wireless
Community Member
Thanks.  That explains it.
1340
