Community Member
WRV200 multi SSID problem
Hi. now i'm using WRV200 Router model.(use Multi SSID)
- first and second SSID and encryption method is WPA-PSK, working well and no problem.
- third SSID is working well first day, but next day, can be search SSID, but not getting a IP and connection failed.
  (if appear this enter administrator mode, not changed any other information, just click to save settings, then i use third SSID in oneday)
- third SSID encryption method is WEP
- Channels are used to channel 6
- in this case, how can i fixed it?
  is this problem, SSID's problems? or channel's proble?
  why occur to multi SSID problem?
pls help me
215
