Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
WRV210 DHCP Lease failure
I recently purchased a new WRV210 as an upgrade from my old, faithful WRT54G wireless router in order to support multiple ssids. When the WRV210 WAN port is connected to my Speedstream 5100B DSL modem, for whatever reason, I cannot obtain a lease address from the DSL modem. I can put the WRT54G in its place and it functions properly. I can also connect the WRV210 downstream of the WRT54G and it will obtain an address from the 54G. The WRV210 is running V1.16 firmware which appears to be the current release. I've seen similar discussions of people adding static addresses as workarounds, but it would seem to me such a basic wireless router function should be a given, especially since the WRT54G can obtain the address without issue. Any help would be appreciated. I'm about ready to return this thing to the dealer if this issue cannot be resolved.
Everyone's tags (1)
Silver
Re: WRV210 DHCP Lease failure
You may have to copy the mac-address from your wrt54g to your wrv210.  The modem registers one mac-address and locks in on it.  If that does not work you may need to contact your isp and have them reset your modem so you can get an ip address from your modem.
David,
Thank you for the advice. The MAC cloning clue was helpful, but did not resolve the issue. In order to allow the WRV210 to obtain an IP address, I had to update the Speedstream 5100B ADSL modem firmware, reset it to a factory-default state, reconfigure it for bridge mode and rely on the router to provide the PPPoE authentication. I tried several modem authentication modes, but found bridge mode to be the most consistent in this configuration.
Thank you again for your help,
rcbash
UPDATE 5:40 PM 2/7/2011 : Just kidding ... still same issue so I am returning it ... back to the linksys garbageG router I got a box full of them !
rcbash I have good news and bad news
good news: I got it working
bad news: the WRV210 is basicly just the linksysrouter with cisco branding on it and !@#$% firmware ..
I called Charter they where no help
I called cisco nice but after 15min of trying to @#$^ing register ... no help .. I told them I was going to downgrade the firmware and the put me on hold then suggested I run latest firmware and change out the cable ... after explaning to them all the details of the issue..
( CISCO thanks for selling me out to spam  ! I love how you wont help your customers without registering ..... but you will surely sell us out ! I got this email shortly after registering ..
Cisco Support
Cisco SBSC – One minute of your time could win you a Flip Video Camera – Service Reques
    Mon, 1/31/11    9KB
* downgrading to Firmware Version: 1.1.17   fixed it for me ... I been online for like 4 days now reflashing it to the most updated may fix it also but then again .. im not messing with it
* errors from cable modem ( these are common errors reguardless of what router I used )
1970-01-01 00:00:17    4-Error    D004.3    ToD request sent- No Response received
1970-01-01 00:00:11    3-Critical    D003.0    DHCP WARNING - Non-critical field invalid in response.
1970-01-01 00:00:07    3-Critical    R002.0    No Ranging Response received - T3 time-out (US 1)
1970-01-01 00:00:18    4-Error    D004.3    ToD request sent- No Response received
1970-01-01 00:00:02    6-Notice    M571.1    Ethernet link up - ready to pass packets
1970-01-01 00:00:19    4-Error    D004.3    ToD request sent- No Response received
1970-01-01 00:00:13    3-Critical    D003.0    DHCP WARNING - Non-critical field invalid in response.
1970-01-01 00:00:02    6-Notice    M571.4    Ethernet link dormant - not currently active
1970-01-01 00:00:21    4-Error    D004.3    ToD request sent- No Response received
1970-01-01 00:00:14    3-Critical    D003.0    DHCP WARNING - Non-critical field invalid in response.
1970-01-01 00:00:18    6-Notice    M571.1    Ethernet link up - ready to pass packets
1970-01-01 00:00:11    6-Notice    M571.4    Ethernet link dormant - not currently active
1970-01-01 00:04:36    4-Error    D004.3    ToD request sent- No Response received
1970-01-01 00:04:29    3-Critical    D003.0    DHCP WARNING - Non-critical field invalid in response.
1970-01-01 00:04:21    3-Critical    R002.0    No Ranging Response received - T3 time-out (US 1)
1970-01-01 00:04:17    3-Critical    R002.0    No Ranging Response received - T3 time-out (US 4)
1970-01-01 00:04:14    3-Critical    R003.0    Init RANGING Critical Ranging Request (17) Retries exhausted
1970-01-01 00:04:14    3-Critical    R002.0    No Ranging Response received - T3 time-out (US 3)
1970-01-01 00:03:09    3-Critical    R003.0    Init RANGING Critical Ranging Request (17) Retries exhausted
1970-01-01 00:03:09    3-Critical    R002.0    No Ranging Response received - T3 time-out (US 3)
1970-01-01 00:02:17    3-Critical    R003.0    Init RANGING Critical Ranging Request (17) Retries exhausted
1970-01-01 00:02:17    3-Critical    R002.0    No Ranging Response received - T3 time-out (US 1)
1970-01-01 00:01:17    3-Critical    T001.0    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:01:11    3-Critical    T002.0    SYNC Timing Synchronization failure - Failed to acquire FEC framing
1970-01-01 00:01:10    3-Critical    T001.0    SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing
1970-01-01 00:00:07    6-Notice    M571.1    Ethernet link up - ready to pass packets
* the file name to goole if you are looking for the manuel for this thing without having to login to cisco ... ( cisco you should allow this without login .. you allow downloading of firmware but not docs ???!?!? )
WRV210_AG_OL-20252.pdf
# url to my cable modem ( charter internet cable )
http://192.168.100.1/RgSignal.asp
# my levels from the cable modem ...
Frequency    579000000 Hz
Signal To Noise Ratio    38.3 dB
Power Level    7.1 dBmV
The Downstream Power Level reading is a snapshot taken at the time this page was requested. Please Reload/Refresh this Page for a new reading
Upstream     Value
Channel ID    1
Frequency    32000000 Hz
Power    35.7 dBmV
forsaken
Re: WCG200 ver.2 drops all internet when surfing the web
Options
    * Mark as New
    * Bookmark
    * Subscribe
    * Subscribe to RSS Feed
    * Highlight
    * Print
    * Report Inappropriate Content
10-28-2009 02:51 PM
Under Wireless tab,change the wireless channel to 11.Under Advance Wireless Settings..Change the Beacon Interval to 50, Change the Fragmentation Threshold to 2304, Change the RTS Threshold to 2304.Under the Security tab,disable " Block Anonymous Internet Requests ".Power cycle the WCG and then,check...If that doesn't help,you need to upgrade the firmware of your modem..You can get the firmware from your ISP.
3877
