Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
WRVS4400N and VPN connection over AES-CBC (256 bits)...
at our office we have a brand new WRVS4400N with 2.0.1.3 fw preinstalled.
In order to make a VPN connection to our cliente, we need to establish an IPSEC VPN with AES-CBC encryption, but in the drop-down list I can only select 3DES.
Does v2.0.2.1 fw update include AES-CBC encryption?
In negative case, how can we add this type of encryption to the router?
Regards and thanks!
WRVS4400N does not support AES for VPN. You might want to consider RV220W or RV120W instead.
Silver
HI,
You will most likely need to move to enterprise small business products - as in the Small Business products the closest thing we have to block ciper IPSec vpn mode would be the SA500 series devices which can select AES-CCM & AES-GCM but not AES-CDC
Hope this is helpful
Jasbryan
737
