WRVS4400N - can't update firmware
I deeply regret having purchased a WRVS4400N less then a year ago.  I have the crappy v1 model with
firmware  V1.1.0.3.  I have downloaded from cisco WRVS4400N support page wrvs4400n_v1_fw_v1.1.13.zip
but I can't update the firmware from a wired connection.
My router stop functioning about every 12-20hrs. (wireless and sometime wired.)  I need to reboot the router on a daylie basis.
I did some basic configuration:
-wireless configuration with mac filtering.
-ip reservation to mac.
-disabled ips (was slowing down my internet connection by 50%.)
When I try to update the firmware I get :
Upgrade file is not the correct type or version for this device.
Upgrade  failed.
Please obtain the correct file and try again.
I'm confused. What a piece of junk!
Thanks to anyone that can help me with this problem / Anyone can recommend a good wireless router for about 300$?
A
1 REPLY
Re: WRVS4400N - can't update firmware
Mr. Alex,
Best way to tacle this issue is if you contact us, we have access to make some changes in your router, and update the firmware.
Almost 98% of the time the latest firmware will carrect this problem, if you will please call at 1866-606-1866 US/ Canada.
720
