11-24-2010 05:40 PM
Recently the web UI in my wrvs4400N router becomes inaccessible. When the Ui becomes inaccessible the router also loses wifi. The strange thing
is that router response to pings and computers connected through hard wired still have internet.
I have to power cycle the router in order to get the web UI to come back. the router's web UI stays up for a couple of days and even stay normal for
a week or so but then the problem comes back. Has anyone experience this problem?
the router has the lates firmware.
12-03-2010 12:09 PM
Hey ocuarezmajr it sounds like a browser cache issue. Next time it does this, try deleting browsing history and if that don't help go to the cmd prompt and run the following command ipconfig -flushdns . Try this and see if you still have the same issue. One more thing you can do is a repair on the local area connection.
Hope this helps.
12-03-2010 01:38 PM
Thanks! i'll give it a try next time it happens and report the results, so
far the router been behaving well.
On Fri, Dec 3, 2010 at 12:09 PM, davicarr <
