11-13-2010 04:34 AM
I have these ports like to block TCP 10001, TCP 36567, TCP 47611, UDP 28086 and UDP 28080, and would like to apply date & time schedule to these port as well.
Can you please advise how to set them up in Cisco WRVS4400N.
Thanks in advance
11-13-2010 12:53 PM
you have to go to Firewall -> IP Based ACL -> Add New Rule -> Service Mangement
at this page you can define which service uses which ports. so you have to create services which include the ports you'd like to block.
when you've added all ports, go back to the add new rule page.
thats where you define which ips should be able / unable to use the defined services. i'm afraid that you'll have to create a rule for every port (service).
hope this helps.
11-16-2010 01:48 PM
Thanks for your reply DominikAU,
I assigned the IP address for computer is 192.168.1.142, when I view Local Network status in DHCP Active IP table stated "192.168.1.101"and the ARP/RARP table stated "192.168.1.142".
What IP address I should use for Source IP and Destination IP in Edit IP ACL rule (In Config IP Based ACL)?
11-22-2010 02:40 PM
Can you please help with my questions.
12-03-2010 07:16 AM
Source ip address is the address your wanting to apply the rule to. Destination is where your wanting to apply rule for that computer going to. The any is a rule for all ip addresses.
