wrvs4400n
Hello guys i have just purchased a WRVS400N
The reason hence buying the router as i am being ip flooded on xbox live, and at the moment I am using a virgin media super hub. i know when the virgin media superhub gets ip flooded cannot handle it as the cpu in the super hub cant handle the requests by the time it filters the packets and has already slowed down and logs of anyhow which is a bit of a shame really i have thought of a private vpn service now i am not to clued up networking ok guys but i thought that i would go for the WRVS400N with using my super hub of virgin media as a modem but done that with all the protection of the linksys WRVS400N which i think has all the correct settings but i would love for someone to perhaps give me a bit of help with this scenario because the reason that the ip flood happens is when someone on xbox live is using cain and able network sniffer i am sure perhaps some have heard of it sniffs all the connections coming of the router of the host is using when you are connected to them via online game play as such and then they send shells to your ip which floods the router which i think form research i have done and i would like protection form that if anyone has any idea or perhaps a bit of knowledge on how to stop this please contact or leave a post
here are the technical specifications on the wrvs4400n
SPECIFICATIONS
Highlights
  • 802.11n wireless networking technology for increased throughput and coverage
  • Full backwards compatibility for 802.11b and 802.11g
  • 4-Port 10/100/1000 switch with automatic rate negotiation and automatic MDI/MDIX detection
  • IPSec VPN tunneling for remote user and branch‑to‑branch connectivity
  • Stateful Packet Inspection Firewall with Network Address Translation (NAT)
  • IDS/IPS network intrusion detection and prevention services with e-mail alerts
  • WMM wireless QoS support- upgradeable to 802.11e
  • Supports WEP, WPA-PSK, WPA2-PSK, WPA-ENT, and WPA2-ENT authentication (802.11i ready)
  • User definable access control lists (ACL) for restricting inbound and outbound traffic flows
  • DHCP Client (WAN) and Server (LAN) with Dynamic DNS support
  • Adjustable Dipole antennae with MIMO 2x3 Diversity
  • Easy installation and configuration Web Interface and QuickVPN software
  • SNMP v1 and v2c support
Specifications
  • Standards
    • IEEE802.11n
    • IEEE802.11g
    • IEEE802.11b
    • IEEE802.3
    • IEEE802.3u
    • 802.1X (security authentication)
    • 802.11i - Ready (security WPA2)
    • 802.11e - Ready (wireless QoS)
    • IPv4 (RFC791)
    • IPv6 (RFC2460)
    • RIPv1 (RFC1058)
    • RIPv2 (RFC1723)
  • Ports
    • Ethernet
    • Power
  • Buttons
    • Reset
  • Cabling Type
    • UTP CAT 5
  • LEDs
    • Power
    • Ethernet
    • Wireless
    • POE
  • Operating System
    • Linux
Performance
  • Built in Web UI for Easy browser-based configuration (HTTP/HTTPS)
  • NAT Throughput: 800Mbps
Management
  • SNMP Version 1, 2c
  • Event Logging
    • Local
    • Syslog
    • Email alerts
  • Firmware Upgradable Through Web-Browser
  • Diags: Flash, RAM
Wireless
  • Spec/Modulation
    • Radio and Modulation Type: 802.11b/DSSS, 11g/OFDM, 11n/OFDM
  • Channels Operating Channels:
    • 11 North America
    • 13 Most of Europe (ETSI and Japan)
  • Number of External Ant. 3 (Omni-Directional)
  • Transmit Power
    • 11b - 16 dBm@1TX, 19 dBm@ 2TX
    • 11g - 13 dBm@1TX, 16 dBm@ 2TX;
    • 11n - 13 dBm@1TX, 16 dBm@ 2TX
  • Antenna Gain: 2 dBi
  • Receiver Sensitivity
    • 11.n: 300Mbps@ -69dbM
    • 11.g: 54Mbps@ -73dBm
    • 11.b: 11Mbps@-88dBM
Security
  • Access Control
    - IP-based Access Control List (ACL)
    - MAC-based wireless access control
  • Stateful Packet Inspection (SPI) firewall
  • Content Filtering
    - URL blocking
    - keyword blocking
  • IPS (Intrusion Prevention System)
    - IP Sweep Detection
    - Application Anomaly Detection (HTTP, FTP, Telnet, RCP)
    - P2P Control
    - Instant Messenger Control
    - L3-L4 Protocol (IP, TCP, UDP, ICMP) Normalization
    - L7 Signature Matching
  • Signature Update
    - Manual download from the web
  • Secure Management
    - HTTPS, username/password
  • 802.1X Port-based RADIUS Authentication (EAP-MD5, EAP-PEAP)
Quality of Service
  • Port-based and application-based priority
  • 4 queues
Network
  • VLAN Support
    - Port-based VLAN
  • DHCP
    - DHCP Server
    - DHCP Client
    - DHCP Relay Agent
  • DNS
    - DNS Relay
    - Dynamic DNS (DynDNS, TZO)
  • NAT
    - PAT
    - NAPT
    - ALG support
    - NAT Traversal
  • DMZ
    - Software configurable on any LAN port
Everyone's tags (1)
1 ACCEPTED SOLUTION
Silver
wrvs4400n
Firstly if your firewall is enabled it should block most attacks. if your using The xBox live feature then turn off UPnP and then port forward then follwing ports to your xBox only.
88 TCP
3074 TCP and UDP
Please note for port forwarding to work correctly you will need to set a Static IP against your Xbox and make sure the IP is not within the DHCP address Range set on the WRVS4400N.
you can set IPS up and use the latest signature, but this will slow down the connection rate since it inspects each packet before passing the data to the lan.
Regards Simon
http://www.linksysinfo.org
Regards Simon http://www.linksysinfo.org
Hall of Fame Super Gold
wrvs4400n
Duplicate post.
Silver
wrvs4400n
88 TCP
3074 TCP and UDP
Regards Simon
973
