Community Member
ASA 5505 IPS AIP SSC-5 Problem
I have recently purchased IPS-AIP-SSC-5 Module for my ASA 5505-Unlimited Basic License.
I got the grean led on ready status.
But the "Show Module" command dosn't show any new Hardware Module Installed.
IOS Version is: 804
ASDM: 615
Can anyone help me with my problem?
Re: ASA 5505 IPS AIP SSC-5 Problem
I would recommend that you go to the netpro forums.
www.cisco.com/go/netpro
This portion of the forums is for the small business products (UC500, SA500 etc).
Community Member
Thank you for your reply, But i figured out that It can NOT be working under 804 IOS.
It is only supported under 8.2x or Later IOS.
I've asked the support to provide me the updates and it is now working fine.
with asdm 6.2x or Later.
Thanks again.
1296
