ASA-55xx confusion
Colleagues,
I have a confusing situation at my new place of employ having to do with Peer-to-Peer VPN to establish.
We have a router supplied by our provider that is configured to establish peer-to-peer connection with our partner and the VPN configuration is set on the ASA. The  supplier Router as well is configured to a public IP NAT port 22 to our ASA.
Kindly I ask how to ensure or check the VPN is truely up ?
many, many thanks for the time
  • Small Business Security
1 ACCEPTED SOLUTION
Hi ben.r@polustech.com,
If you are using CLI you can run the following commands:
sh crypto isakmp sa
sh crypto ipsec sa peer <peerip>
If you are using ASDM:
Monitoring> VPN> VPN Connection Graphs> IPSec Tunnels
http://www.cisco.com/c/en/us/td/docs/security/asa/asa96/asdm76/vpn/asdm-76-vpn-config/vpn-asdm-monitor.html
Hope this info helps!!
Rate if helps you!!
-JP-
1 REPLY
sh crypto isakmp sa
Rate if helps you!!
-JP-
34
