Cisco asa 5505 port redirection on different port
I want to do a port redirection from the outside to a different port inside. From my public ip, iwant to use the port 6100 to communicate with the port 80 on the ip 192.168.1.10
thanks
Hi , what is asa code you are
Hi ,
 what is asa code you are running on your ASA box  ??
For Asa Code upto 8.2
hostname(config)# static (inside,outside) tcp interface 6100 192.168.1.10 http netmask 255.255.255.255
After ASA code 8.3
object network webserver
 host 192.168.1.10
object service tcp_80
service tcp destination eq www
object service tcpout_6100
 service tcp source eq 6100
nat (Inside,Outside) 1 source static webserver interface service tcp_80 tcpout_6100
Number 1 is given to specific sequence of NAT during NAT translation .
Sandy
Also do I need access rules ?
Also do I need access rules ? Thanks for helping me !
Hi ,  Yes you need firewall
Hi ,
  Yes you need firewall rule to allow source subnet to access your webserver on port 6100 .
Sandy
Hi I forgot to mentionned
Hi I forgot to mentionned that I have several public Ip is it the same command ?
49
