Cisco ASDM-IDM Launcher with ASA 5505 & 5515
I replaced an old edge router with a new ASA5515, and I still have an existing ASA5505 model on site. I am not able to use the Cisco ASDM-IDM Launcher with both ASA units. It works fine with the new ASA5515, but when I try to connect to the ASA5505 I get a "Unable to launch device manager from 192.168.x.x", press OK.
The ASDM-IDM Launcher worked fine for the ASA5505 before the ASA5515 upgrade. From checking the web, this might relate to Java. I have tried downgrading to v7 and v6 of Java which does not fix the ASA5505 issue.
I would like to be able access all my ASA's from a single desktop/laptop.
Can anyone shed some light?
Thanks.
Frank
Everyone's tags (1)
here's some more info on Java
here's some more info on Java 1.7 it seems that security has changed a bit in 1.7
http://www.cisco.com/en/US/docs/security/asdm/7_1/release/notes/rn71.html#wp551300
I had this problem yesterday.
I had this problem yesterday. I tried so many java versions but the problem is not JAVA is the browser. I'm on windows 8.1 but as soon as I used firefox there was no problem.
Well, I forgot that I put my
Well, I forgot that I put my workstation on a different subnet right before the ASA replacement. And I did not adjust the Management Access List for my ip address. Thanks for the help.
441
