Community Member
Cisco SA-540
I configured NAT on Cisco 540 by allowing all traffic from secure LAN to unsecure WAN .Intrnet is working but I cannot access https sites.I alreay configured SSL VPN and Portforwafing on port no 30001.Can anybody suggest a solution.
Everyone's tags (1)
Community Member
Re: Cisco SA-540
Hi joby_ccna,
From your description it seems than your LAN requests for https pages are not passing though the SA 540.  This can be caused by either a firewall rule blocking HTTPS traffic from LAN to WAN, or something else in your network blocking such traffic.
Can you send us your configuration file, I will load it and try it  out locally. Please change any password and/or sensitive information  from the configuration.
To get the configuration file you must be logged in and on the Administrator Tab:
1.       Click on Firmware & Configuration
2.       Click on network
3.       In the middle look for the Backup/Restore Settings
4.       then Click Backup.
If you do not want to post the items in the forum, please feel free to send me the configuration in private message.
Best regards,
