CONFIGURAR ISA 570
HELP SETTING UP THE ISA 570, HAVE ALL CONFIGURATION PARAMETERS
SETUP EXAMPLE OF MY PROVIDER
WAN
IP 190.124.xxx.xx
MASK: 255.255.255.252
GATEWAY: 190.124.XXX.XX
DNS: 190.124.XXX.XX
CONFGIRUACION THAT I HAVE LAN
DHCP settings: RANGE: 192.168.0.100 192.168.0.200 AL
IP: 192.168.0.100
MASK: 255.255.255.0
GATEWAY: 192.168.0.2
DNS: 192.168.0.2
They will have a process to help me set achievement not activate network
1 ACCEPTED SOLUTION
Hi , What you want to setup ?
Hi ,
 What you want to setup ?? on your ISA 570 .
Sandy
Hi ,
Sandy
Hello, what I need is to take
Hello, what I need is to take steps to be properly configured network company, the proper steps of installation, I have a local network of 30 machines, and I can not set up well and necesisto the steps to do it right
Hello, have you tried using
Hello, have you tried using the setup wizard?  Here is a detailed instruction: http://sbkb.cisco.com/CiscoSB/Loginr.aspx?vw=1&pid=2&docid=f3301c51a6eb44e6921da8236d60a6e5_Setup_Wizard_on_ISA500_Series_Integrated_Security_Appliance.xml&app=search&login=1
-- please remember to rate and mark answered helpful posts --
82
